Was du brauchst
Carefully remove the rubber fan bumper from the edge of the heat sink.
Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
One of the screws holding the top shell of the fan assembly is hidden just behind the I/O board cable.
Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
Remove the I/O board cable bracket.
Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
Lift the logic board end of the I/O board cable straight up to bend it out of the way.
Remove the following screws securing the fan assembly cover to the rest of the assembly:
One 5.0 mm T5 Torx screw.
3 Phillips #000 screws.
3 weitere Personen haben diese Anleitung absolviert.
