Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If your InFocus IN3104 has fuzzy or distorted color, this guide is for you. The fuzzy or distorted color most likely means that your color wheel is broken or defective. If your color wheel is broken it will need to be replaced. The color wheel provides color to the projection and is needed for display.
  1. Turn the projector so that the lens is facing you. On the left side of the projector, there is a screw and a knob inside of the small grate. Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. Use a Phillips #1 screwdriver to remove the seven 6 mm screws. Use a Phillips #1 screwdriver to remove the two 5 mm screws. Remove the top cover.
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. Use a Phillips #1 screwdriver to remove the nine 6 mm screws. Lift up the metal cover and set it aside to reveal the motherboard.
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  4. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  5. Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger. Pull out the blue-tipped, white ribbon cable from the connector. Remove the metal cover.
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
  6. Unplug two cables from the edge of the motherboard labeled 80.87 MO and KYO. Unplug two cables from the edge of the motherboard labeled 80.87 MO and KYO. Unplug two cables from the edge of the motherboard labeled 80.87 MO and KYO.
    • Unplug two cables from the edge of the motherboard labeled 80.87 MO and KYO.
  7. Carefully lift up the black paper cover. Do not completely remove it from the device. Lift the paper cover up to reveal two 6mm screws.
    • Carefully lift up the black paper cover. Do not completely remove it from the device.
    • Lift the paper cover up to reveal two 6mm screws.
  8. Use a Phillips #1 screwdriver to remove the two 6mm screws. Remove the color wheel from the device by lifting it out of the projector.
    • Use a Phillips #1 screwdriver to remove the two 6mm screws.
    • Remove the color wheel from the device by lifting it out of the projector.
Abschluss
Christopher Held
181 Reputation
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 94
