Zum Hauptinhalt wechseln
InFocus IN3104 Filter Replacement
Was du brauchst
  1. InFocus IN3104 Filter Replacement, Top Cover: Schritt 1, Bild 1 von 3 InFocus IN3104 Filter Replacement, Top Cover: Schritt 1, Bild 2 von 3 InFocus IN3104 Filter Replacement, Top Cover: Schritt 1, Bild 3 von 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Filter Replacement: Schritt 2, Bild 1 von 3 InFocus IN3104 Filter Replacement: Schritt 2, Bild 2 von 3 InFocus IN3104 Filter Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Filter Replacement, Filter: Schritt 3, Bild 1 von 3 InFocus IN3104 Filter Replacement, Filter: Schritt 3, Bild 2 von 3 InFocus IN3104 Filter Replacement, Filter: Schritt 3, Bild 3 von 3
    • Use a Phillips # 1 screw driver to remove the 6 mm screw that secures the filter.
    • Once the screw is removed, remove the filter by pulling it straight out.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 287
