Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This Metal Cover needs to be removed in order to replace most parts in the device.
  1. Turn the projector so that the lens is facing you. On the left side of the projector, there is a screw and a knob inside of the small grate. Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. Use a Phillips #1 screwdriver to remove the seven 6 mm screws. Use a Phillips #1 screwdriver to remove the two 5 mm screws. Remove the top cover.
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Use a Phillips #1 screwdriver to remove the nine 6 mm screws. Lift up the metal cover and set it aside to reveal the motherboard.
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  5. Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger. Pull out the blue-tipped, white ribbon cable from the connector. Remove the metal cover.
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
Abschluss
Christopher Held
181 Reputation
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 59
