Was du brauchst
Use a Phillips #1 screwdriver to remove the 1.2 cm Phillips-head screw from each side of the projector.
Use your hands to slide the top plate off of the projector.
Lift and remove the plate.
Use the opening tool to slide off the control panel cover.
Remove the cover.
Unplug the ribbon cable from the edge of the LED touch board.
Remove the LED touch board.
Fast fertig!
Abschluss
