Zum Hauptinhalt wechseln
InFocus IN35W Daughterboard Replacement
Was du brauchst
  1. InFocus IN35W Daughterboard Replacement, Top Plate: Schritt 1, Bild 1 von 3 InFocus IN35W Daughterboard Replacement, Top Plate: Schritt 1, Bild 2 von 3 InFocus IN35W Daughterboard Replacement, Top Plate: Schritt 1, Bild 3 von 3
    • Use the plastic opening tool to remove the front plastic casing surrounding the lens.
    • Pry apart the clips securing the top and bottom of the device using the plastic opening tool.
  2. InFocus IN35W Daughterboard Replacement: Schritt 2, Bild 1 von 2 InFocus IN35W Daughterboard Replacement: Schritt 2, Bild 2 von 2
    • Pull the top piece up.
    • The two gray ventilation grates will slip off the device.
  3. InFocus IN35W Daughterboard Replacement: Schritt 3, Bild 1 von 2 InFocus IN35W Daughterboard Replacement: Schritt 3, Bild 2 von 2
    • Detach the white speaker wire that connects the motherboard to the top piece.
    • Remove the top cover from the device.
  4. InFocus IN35W Daughterboard Replacement, Daughterboard: Schritt 4, Bild 1 von 2 InFocus IN35W Daughterboard Replacement, Daughterboard: Schritt 4, Bild 2 von 2
    • Remove one 7 mm screw from the silver fastening plate using a Torx T9 screwdriver.
  5. InFocus IN35W Daughterboard Replacement: Schritt 5, Bild 1 von 2 InFocus IN35W Daughterboard Replacement: Schritt 5, Bild 2 von 2
    • Remove eight 7 mm screws from the daughterboard using a Torx T9 screwdriver.
  6. InFocus IN35W Daughterboard Replacement: Schritt 6, Bild 1 von 2 InFocus IN35W Daughterboard Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the red and black bundled cable from its connector on the daughterboard.
    • Grab the daughterboard by the sides and carefully lift it out from the top plate.
Abschluss
Grace Hubert
608 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 1-2, Simcock Fall 2021 Mitglied von UMass Dartmouth, Team 1-2, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G2
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 65
