Einleitung
The projector lamp is the most essential part of your InFocus IN35W projector because it creates the light that shines through the DLP or LCD system and makes clear, bright, vivid images your projector displays. The lamp could be the reason why your picture isn’t coming out as clear anymore. Follow these steps to learn how to access the lamp and how to replace it if needed.
Was du brauchst
Flip the projector on its backside and lay it on a flat surface.
Remove the lamp door gently with your hands or a plastic opening tool.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
