Einleitung
Removing the top plate on the InFocus IN35W will allow you also to access any other parts inside of the projector that may need fixing, including the daughterboard, motherboard, fan, or lamp. Follow these steps to learn how to correctly take the top plate off of your device.
Was du brauchst
Use the plastic opening tool to remove the front plastic casing surrounding the lens.
Pry apart the clips securing the top and bottom of the device using the plastic opening tool.
Detach the white speaker wire that connects the motherboard to the top piece.
Remove the top cover from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
