Zum Hauptinhalt wechseln
  1. Flip the projector right-side up and turn it so that the back ports are facing you. Remove the 7mm metallic hex screws using the flat-head screwdriver Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
    • Flip the projector right-side up and turn it so that the back ports are facing you.
    • Remove the 7mm metallic hex screws using the flat-head screwdriver
    • Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
  2. Remove the two 77mm screws that are located nearest to the back panel ports. Use the T10 Torx screwdriver head. Next, remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
    • Remove the two 77mm screws that are located nearest to the back panel ports. Use the T10 Torx screwdriver head.
    • Next, remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
    • Flip the projector back over.
    • Then proceed to lifting up the main lid cautiously to avoid ripping the electrical strips.
  3. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  4. Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling. Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
    • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
  5. Place the top shell of the projector down. Remove the speaker wires from the white tabs. Use the Phillips 0 screwdriver to remove the four 5.5 mm screws.
    • Place the top shell of the projector down.
    • Remove the speaker wires from the white tabs.
    • Use the Phillips 0 screwdriver to remove the four 5.5 mm screws.
    • Carefully lift the speakers to remove them.
Abschluss
Jorge L Navarro
533 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 13-17, Regan Winter 2014 Mitglied von Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
Insgesamt: 338
