Zum Hauptinhalt wechseln
InFocus Screenplay 4805 Lamp Rebuild
Was du brauchst
  1. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: Schritt 1, Bild 1 von 2 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: Schritt 1, Bild 2 von 2
    • This guide assumes tht you have removed the lamp unit from the projector. If you have not, refer to this guide first: InFocus Screenplay 4805 Lamp Replacement
    • Slide the bulb housing out of the projector.
    • Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
  2. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: Schritt 2, Bild 1 von 2 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: Schritt 2, Bild 2 von 2
    • This step is only required when rebuilding the old lamp with a replacement bulb.
    • Gently pull the top of the bulb housing off.
    • Lift up the middle of the bulb housing to remove it.
    • Be careful of loose parts, such as the metal housing and the glass focusing lens.
  3. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: Schritt 3, Bild 1 von 3 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: Schritt 3, Bild 2 von 3 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: Schritt 3, Bild 3 von 3
    • Unhook the spring from the bulb housing.
    • Gently remove the bulb.
Abschluss
To reassemble the device, follow these instructions in reverse order.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 121
