Einleitung
Replace the built-in 2.5 watt mono speaker if you are experiencing sound problems.
For this project you will need a torx screwdriver and metal spudger. You may need a can of compressed air to clean the inside of the projector.
Was du brauchst
Flip the projector on its back.
Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
Turn the projector, facing the back cable board towards you.
Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
Gently take off back cable panel.
Turn the projector so the front side with the lens is facing you.
Gently pry the both of the grey lens rings using the metal spudger.
Now that the screws have been removed, proceed with the removal of the outer panel.
Gently remove the front lens panel.
Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
Locate the circle speaker on the lower left corner of the inside of the lid.
Use the Phillips #1 screwdriver to remove the three gold 2cm gold screws.
Remove the speaker from the lid and flip metallic side down.
Gently pull the white connector to release the speaker.
Lift the speaker out of its holding.
