Einleitung
This guide shows how to open up the projector. This will allow for following actions to replace parts.
  1. Flip the projector on its back. Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws. Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
  2. Turn the projector, facing the back cable board towards you. Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Turn the projector so the front side with the lens is facing you. Gently pry the both of the grey lens rings using the metal spudger. Gently pry the both of the grey lens rings using the metal spudger.
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
  5. Now that the screws have been removed, proceed with the removal of the outer panel.
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
  6. Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
Ziellinie
Marilyn Urness
609 Reputation
6 Anleitungen geschrieben
There’s a 4th orange screw to be removed on the STEP1 image. It’s located on the top right corner of the projector body, if looking at it as shown on the photo...STEP4 image - all 3 plastic latches at the top panel are damaged. That’s why at the shown case, the front panel goes off easily.If the projector has never been opened, it is actually very hard to remove the front panel. One can release the latches with thin tea spoon (f.ex.), operating it with caution, over the front grill.
madyogi - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 80
