Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The InFocus X2 projector’s lamp can become burned out, resulting in a picture that is blacked out on one side. This guide will describe how to access the lamp and replace the burned-out part with a new one.
Ersatzteile
  1. Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds. Insert the Jimmy into one of the two notches on the lamp door's top edge. Then use light force on the Jimmy to pry the latch away from the door.
    • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
    • Insert the Jimmy into one of the two notches on the lamp door's top edge.
    • Then use light force on the Jimmy to pry the latch away from the door.
    • If necessary, insert the Jimmy into the second latch and separate it from the projector.
    • Remove the door away from the projector by hand.
  2. Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug. Then pull the plug away from the projector. Then pull the plug away from the projector.
    • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
    • Then pull the plug away from the projector.
  3. Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing. For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector.  If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it. For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector.  If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
    • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
    • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
  4. Pull on the bottom plastic tab and remove the lamp by hand.
    • Pull on the bottom plastic tab and remove the lamp by hand.
  5. Insert the replacement lamp into the projector.
    • Insert the replacement lamp into the projector.
Abschluss
Caution: The old bulb contains mercury. Please recycle it in a safe and appropriate manner. Look for your local recycling information at https://earth911.com/
Angehängte Dateien
Paul Duarte
494 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 Mitglied von UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G3
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 7
Insgesamt: 120
