Zum Hauptinhalt wechseln
Infant Optics DXR-5 Camera Lens Replacement
Was du brauchst
  1. Infant Optics DXR-5 Camera Lens Replacement, Camera: Schritt 1, Bild 1 von 2 Infant Optics DXR-5 Camera Lens Replacement, Camera: Schritt 1, Bild 2 von 2
    • Using a Phillips #2 screwdriver, remove the four, 6.0 mm Phillips screws from the back of the camera unit.
  2. Infant Optics DXR-5 Camera Lens Replacement: Schritt 2, Bild 1 von 2 Infant Optics DXR-5 Camera Lens Replacement: Schritt 2, Bild 2 von 2
    • Pull up on the two beige tabs to the left and right of the ribbon connected to the camera.
    • Pull the ribbon straight out from the camera.
  3. Infant Optics DXR-5 Camera Lens Replacement: Schritt 3, Bild 1 von 2 Infant Optics DXR-5 Camera Lens Replacement: Schritt 3, Bild 2 von 2
    • Remove the front face plate of the camera unit by carefully pulling it off.
  4. Infant Optics DXR-5 Camera Lens Replacement, Camera Lens: Schritt 4, Bild 1 von 2 Infant Optics DXR-5 Camera Lens Replacement, Camera Lens: Schritt 4, Bild 2 von 2
    • Using a Phillips #2 screwdriver, remove the two 6.0 mm Phillips screws that hold the camera lens on.
    • These two screws have a different thread than the four screws that secure the camera unit's housing.
Abschluss
Charles Neal
687 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 6-2, Remmell Fall 2015 Mitglied von USF Tampa, Team 6-2, Remmell Fall 2015
USFT-REMMELL-F15S6G2
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 610
