Zum Hauptinhalt wechseln
Infant Optics DXR-5 Monitor Screen Replacement
Was du brauchst
  1. Infant Optics DXR-5 Monitor Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Infant Optics DXR-5 Monitor Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Press on the blue clip on the back and slide it down.
    • In the second picture there is a slight gap at the top of the blue clip.
  2. Infant Optics DXR-5 Monitor Screen Replacement: Schritt 2, Bild 1 von 1
    • Pull the blue clip away from the body of the hand held monitor.
  3. Infant Optics DXR-5 Monitor Screen Replacement: Schritt 3, Bild 1 von 1
    • Slide the rear white panel off as shown.
  4. Infant Optics DXR-5 Monitor Screen Replacement: Schritt 4, Bild 1 von 2 Infant Optics DXR-5 Monitor Screen Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery by pushing in on the right side and then pulling the battery up and out of the body of the hand held monitor.
  5. Infant Optics DXR-5 Monitor Screen Replacement, Monitor Screen: Schritt 5, Bild 1 von 3 Infant Optics DXR-5 Monitor Screen Replacement, Monitor Screen: Schritt 5, Bild 2 von 3 Infant Optics DXR-5 Monitor Screen Replacement, Monitor Screen: Schritt 5, Bild 3 von 3
    • Remove the four 6.0 mm Phillips screws located on the back of the hand held monitor using a Phillips #2 screwdriver.
    • There are two types of screws. Be sure to return the screws to their respective holes upon reassembly.
  6. Infant Optics DXR-5 Monitor Screen Replacement: Schritt 6, Bild 1 von 2 Infant Optics DXR-5 Monitor Screen Replacement: Schritt 6, Bild 2 von 2
    • Carefully remove the clear face plate on the front of the hand held monitor using a plastic spudger and a suction cup.
    • Use a heat source to loosen the adhesive around the edge of the face plate before applying any pressure to the face plate.
  7. Infant Optics DXR-5 Monitor Screen Replacement: Schritt 7, Bild 1 von 2 Infant Optics DXR-5 Monitor Screen Replacement: Schritt 7, Bild 2 von 2
    • Using a Phillips #2 screwdriver, remove the two 6.0 mm Phillips screws that are exposed after removing the face plate.
  8. Infant Optics DXR-5 Monitor Screen Replacement: Schritt 8, Bild 1 von 2 Infant Optics DXR-5 Monitor Screen Replacement: Schritt 8, Bild 2 von 2
    • Using a drill carefully drill out the plastic posts that connect the mother board to the face plate.
  9. Infant Optics DXR-5 Monitor Screen Replacement: Schritt 9, Bild 1 von 2 Infant Optics DXR-5 Monitor Screen Replacement: Schritt 9, Bild 2 von 2
    • Carefully open the hand held monitor and flip the screen (highlighted in red) out of the way.
  10. Infant Optics DXR-5 Monitor Screen Replacement: Schritt 10, Bild 1 von 2 Infant Optics DXR-5 Monitor Screen Replacement: Schritt 10, Bild 2 von 2
    • Remove the hand held monitor screen from the mother board by carefully pulling from the point where it is attached with an adhesive to the mother board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Charles Neal
687 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 6-2, Remmell Fall 2015 Mitglied von USF Tampa, Team 6-2, Remmell Fall 2015
USFT-REMMELL-F15S6G2
5 Mitglieder
Ein Kommentar
Any ideas on where to source the replacement screen?
Abdullah - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 1,984
