Einleitung
Replace the antenna to receive better signal.
Was du brauchst
Locate antenna connection.
Desolder wire to remove. An antenna of a new length can be soldered to the board for improved signal strength.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
That’s fine but what antenna did you purchase? My antennae wire is actually broken, started out with the plastic piece breaking then the cable snapped.
I would also like to know what replacement antenna you used.
