Zum Hauptinhalt wechseln
Infant Optics DXR-8 Camera Speaker Replacement
Was du brauchst
  1. Infant Optics DXR-8 Camera Speaker Replacement, Infant Optics DXR-8 Camera Disassembly: Schritt 1, Bild 1 von 2 Infant Optics DXR-8 Camera Speaker Replacement, Infant Optics DXR-8 Camera Disassembly: Schritt 1, Bild 2 von 2
    • Position the camera with bottom facing toward you.
    • Using the plastic opening tool, remove all four rubber ends from the bottom of the camera.
  2. Infant Optics DXR-8 Camera Speaker Replacement: Schritt 2, Bild 1 von 2 Infant Optics DXR-8 Camera Speaker Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 4 mm screws beneath rubber ends using the Phillips #00 screwdriver.
  3. Infant Optics DXR-8 Camera Speaker Replacement: Schritt 3, Bild 1 von 1
    • Open the bottom of the camera to reveal the circuit board and speaker.
  4. Infant Optics DXR-8 Camera Speaker Replacement, Camera Speaker: Schritt 4, Bild 1 von 1
    • Disconnect the speaker cable from the circuit board for ease of access.
  5. Infant Optics DXR-8 Camera Speaker Replacement: Schritt 5, Bild 1 von 1
    • Lift the speaker from the casing using a metal spudger.
    • Place a new 8W speaker in the casing.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 29
Insgesamt: 2,199
