Was du brauchst
Position the camera with bottom facing toward you.
Using the plastic opening tool, remove all four rubber ends from the bottom of the camera.
Remove the four 4 mm screws beneath rubber ends using the Phillips #00 screwdriver.
Disconnect the speaker cable from the circuit board for ease of access.
Lift the speaker from the casing using a metal spudger.
Place a new 8W speaker in the casing.
Fast fertig!
Abschluss
