Zum Hauptinhalt wechseln
Infant Optics DXR-8 Power Button Replacement
Was du brauchst
  1. Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: Schritt 1, Bild 1 von 3 Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: Schritt 1, Bild 2 von 3 Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: Schritt 1, Bild 3 von 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Power Button Replacement: Schritt 2, Bild 1 von 3 Infant Optics DXR-8 Power Button Replacement: Schritt 2, Bild 2 von 3 Infant Optics DXR-8 Power Button Replacement: Schritt 2, Bild 3 von 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Power Button Replacement: Schritt 3, Bild 1 von 3 Infant Optics DXR-8 Power Button Replacement: Schritt 3, Bild 2 von 3 Infant Optics DXR-8 Power Button Replacement: Schritt 3, Bild 3 von 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Power Button Replacement, Power Button: Schritt 4, Bild 1 von 1
    • The power button is located at the top of the device.
  5. Infant Optics DXR-8 Power Button Replacement: Schritt 5, Bild 1 von 1
    • Remove the button by picking it up out of the hole it is connected to.
  6. Infant Optics DXR-8 Power Button Replacement: Schritt 6, Bild 1 von 1
    • Insert a new button by placing the small end in the hole to connect the button to the device.
Abschluss
To reassemble your device, follow the instructions in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Where did you get the replacement switch?
Dave Peterson - Antwort
Where can you purchase a new power switch on the circuit board for replacement?
Derrick Silvestri - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 4,856
