Was du brauchst
Using the plastic opening tool, remove screen protector from front of monitor.
Remove the six 4mm screws using a Phillips #00 screwdriver.
Remove the screen, exposing the circuit board.
Turn device over to expose rear circuit board.
Insert a new button by placing the small end in the hole to connect the button to the device.
To reassemble your device, follow the instructions in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Where did you get the replacement switch?
Where can you purchase a new power switch on the circuit board for replacement?
