Was du brauchst
Remove Red Zip tie by simply cutting it. DON'T FORGET THIS IS HERE YOU WILL NEED TO ATTACH ANOTHER ONE DURING REASSEMBLY .
Next go ahead and remove the silk wire cover , it simply comes off by separating the Velcro .
Remove all 5 Screws on the front side of the footrest frame.
This power connector is threaded through this plastic piece . Take care when pulling cover off.
First You need to remove the belt from the motor. To do this simply use your fingers and pinch the belt and at the same time spin it and it should pop right off.
once the belt is removed go ahead and unscrew the 4 bolts. Mind you the motor will fall once the screws are removed keep your other hand on it at all times
In order to access the back screws under the bar use the holes marked in the photo.
In order to get new motor into frame and attach belt you need to put 2 screws in the motor LOOSELY DO NOT TIGHTEN ANYTHING yet .
Now slip on the belt to loose motor and with a good amount of force push to the right until motor belt and motor mount point line up . Now tighten those 2 screws. Motor should be mounted and you can install last 2 bolts.
