Zum Hauptinhalt wechseln
Infinity v2 10.1 Back Case Replacement
Was du brauchst
  1. Infinity v2 10.1 Back Case Replacement, Back Case: Schritt 1, Bild 1 von 3 Infinity v2 10.1 Back Case Replacement, Back Case: Schritt 1, Bild 2 von 3 Infinity v2 10.1 Back Case Replacement, Back Case: Schritt 1, Bild 3 von 3
    • Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
    • Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
    • There will be a slight click noise as you free each tab.
    • Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
  2. Infinity v2 10.1 Back Case Replacement: Schritt 2, Bild 1 von 2 Infinity v2 10.1 Back Case Replacement: Schritt 2, Bild 2 von 2
    • Remove the speakers from the case by gently lifting them up and out of their slots.
Abschluss
Nate Rice
321 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S2-G4, Barthe Fall 2019 Mitglied von UMass Dartmouth, Team S2-G4, Barthe Fall 2019
UMASSD-BARTHE-F19S2G4
3 Mitglieder
6 Anleitungen geschrieben
0Leitfaden Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 523
