Zum Hauptinhalt wechseln
Infinity v2 10.1 Camera Replacement
Was du brauchst
  1. Infinity v2 10.1 Camera Replacement, Back Case: Schritt 1, Bild 1 von 3 Infinity v2 10.1 Camera Replacement, Back Case: Schritt 1, Bild 2 von 3 Infinity v2 10.1 Camera Replacement, Back Case: Schritt 1, Bild 3 von 3
    • Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
    • Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
    • There will be a slight click noise as you free each tab.
    • Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
  2. Infinity v2 10.1 Camera Replacement: Schritt 2, Bild 1 von 2 Infinity v2 10.1 Camera Replacement: Schritt 2, Bild 2 von 2
    • Remove the speakers from the case by gently lifting them up and out of their slots.
  3. Infinity v2 10.1 Camera Replacement, Camera: Schritt 3, Bild 1 von 1
    • Use your thumb or opening tool to lift the black connector holding in the ribbon cable.
  4. Infinity v2 10.1 Camera Replacement: Schritt 4, Bild 1 von 1
    • Remove the camera by gently picking it up and pulling it free from the connector.
    • Avoid touching the lens of either camera.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
sammytarbokas
193 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S2-G4, Barthe Fall 2019 Mitglied von UMass Dartmouth, Team S2-G4, Barthe Fall 2019
UMASSD-BARTHE-F19S2G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 111
