Einleitung
If your Inse vacuum (Model N500) dustbin is cracked, spilling out debris, or has distorted in a way that prevents closure, use this guide for dustbin replacement.
Was du brauchst
Remove the single 4 mm screw from the circuit board using a Phillips #0 screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
