Einleitung
This guide will take you through the process of replacing a broken or unusable screen on the Insignia 24" LED Roku TV.
Was du brauchst
Rest the TV on its top edge so you have access to the base.
Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
Remove the base from the frame.
Lay the TV face down.
Use the Phillips #00 screwdriver to remove all of the Phillips Head Screws from the the back of the TV.
Stand the TV on its top edge.
Gently pry apart the front and back of the TV.
Remove all the pieces of tape to detach the wires from both sides.
You want to gently peel the tape off, without pulling on the wires.
Spread apart your TV the rest of the way, but do not disconnect any of the wires.
Remove the tape that is holding the silver rectangular piece from the house.
Using the Phillips 00 Screwdriver, remove the screws that are also holding the silver rectangular piece to the house.
Remove the plastic casing from the glass screen.
Then carefully remove metal backing from glass screen and separate the layer of plastic from the glass screen.
Separate plastic screen protector layers from both the backing and glass screen.
Find the display board and unplug the white ribbon cord from the board.
Squeeze both sides of the plug to release the cord.
Using same screwdriver, unscrew the screws that are on the green display board.
Separate the green display board from its metal backing.
To reassemble your TV, follow these instructions in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
