Einleitung
Circuit boards may require replacement after consistent use. This guide will show how to remove the circuit board.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Use a Phillips head #2 screwdriver to remove the 6mm screw.
    • Use a Phillips head #2 screwdriver to remove the 6mm screw.
  2. Twist the light grey plastic until the holes align with the blockers.
    • Twist the light grey plastic until the holes align with the blockers.
    • Remove the light grey plastic cover.
    • Remove the power cord from the slot it is inserted in.
    • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
    • Pinch the small white component connected to the circuit board.
    • Once pinched, wiggle this component until it is disconnected.
    • Pinch the red component connected to the circuit board.
    • Wiggle the wide white component until it is removed from the circuit board.
    • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
    • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
    • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
    • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
    • Remove and replace the circuit board.
Abschluss
Savannah Webb
Mitglied seit 18.01.2018
639 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S12-G3, Banghart Winter 2018 Mitglied von Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 18
Insgesamt: 125
