Zum Hauptinhalt wechseln
Insignia Flex 10.1 NS-P10A6100 Screen Replacement
Was du brauchst
  1. Insignia Flex 10.1 NS-P10A6100 Screen Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Make sure your tablet is turned off and not connected to a power source to prevent personal injury.
    • The volume rocker and power button located on the top edge by the camera are not connected pieces and will become free from the device once the front panel is removed from the back case. They are easily put back in place when reassembling the tablet.
    • Position the tablet with the top edge by the camera facing down.
    • Insert the plastic opening tool between the front panel and back case at the upper left hand corner of the tablet.
    Frag FixBot
    Kommentar hinzufügen
  2. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 2, Bild 1 von 2 Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 2, Bild 2 von 2
    • Slide the plastic opening tool along the edge of the tablet between the front panel and back case.
    • Repeat this process for the two shorter edges of the tablet leaving the top edge by the camera still snapped in place.
    Frag FixBot
  3. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 3, Bild 1 von 1
    • Using an unfolding motion along the top edge of the tablet, carefully separate the front panel from the back case.
    Frag FixBot
  4. Insignia Flex 10.1 NS-P10A6100 Screen Replacement, Camera: Schritt 4, Bild 1 von 2 Insignia Flex 10.1 NS-P10A6100 Screen Replacement, Camera: Schritt 4, Bild 2 von 2
    • Using the Phillips #000 screw driver, unscrew the two 4 mm screws securing the camera to the front panel in a counterclockwise direction.
    • The two screws are very small, so be careful not to lose them after unscrewing them.
    Frag FixBot
  5. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 5, Bild 1 von 1
    • Using the plastic opening tool, lift up the black retaining flap that secures the camera ZIF (zero insertion force) ribbon connector to the motherboard.
    Frag FixBot
  6. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 6, Bild 1 von 1
    • Pull the camera ZIF (zero insertion force) ribbon connector out from underneath the black retaining flap.
    • Remove the camera.
    Frag FixBot
  7. Insignia Flex 10.1 NS-P10A6100 Screen Replacement, Screen: Schritt 7, Bild 1 von 2 Insignia Flex 10.1 NS-P10A6100 Screen Replacement, Screen: Schritt 7, Bild 2 von 2
    • Using the Phillips #000 screw driver, unscrew the four 4 mm screws securing the four gray clasps to the front panel in a counterclockwise direction.
    • The four screws are very small, so be careful not to lose them after unscrewing them.
    Frag FixBot
  8. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 8, Bild 1 von 1
    • Using the plastic opening tool, pry the four gray clips from the front panel.
    • The gray clips rest lightly in place on the front panel, so minimal force is required to remove and place them.
    Frag FixBot
  9. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 9, Bild 1 von 3 Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 9, Bild 2 von 3 Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 9, Bild 3 von 3
    • Using the Phillips #000 screw driver, unscrew the four 4 mm screws securing the speakers to the front panel in a counterclockwise direction.
    Frag FixBot
  10. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 10, Bild 1 von 2 Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 10, Bild 2 von 2
    • Using the Phillips #000 screw driver, unscrew the three 4 mm screws securing the motherboard to the front panel in a counterclockwise direction.
    • The three screws are very small, so be careful not to lose them after unscrewing them.
    Frag FixBot
  11. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 11, Bild 1 von 1
    • Using the plastic opening tool, lift up the black retaining flap that secures the volume and power button ZIF (zero insertion force) ribbon connector to the motherboard.
    Frag FixBot
  12. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 12, Bild 1 von 1
    • Pull the ZIF (zero insertion force) ribbon connector out from underneath the black retaining flap.
    Frag FixBot
  13. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 13, Bild 1 von 2 Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 13, Bild 2 von 2
    • Using the plastic opening tool, remove the silver tape covering the display ZIF (zero insertion force) ribbon connector.
    Frag FixBot
  14. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 14, Bild 1 von 1
    • Using the plastic opening tool, lift up the black retaining flap that secures the display ZIF (zero insertion force) ribbon connector to the motherboard.
    Frag FixBot
  15. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 15, Bild 1 von 1
    Frag FixBot
  16. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 16, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Heavy-Duty Spudger
    • Position the tablet with the top edge by the cameras facing up.
    • Insert the heavy-duty spudger at the top right corner.
    Frag FixBot
  17. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 17, Bild 1 von 1
    • Lift the screen from the front panel with a prying motion to detach it from the clips holding it in place.
    Frag FixBot
  18. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 18, Bild 1 von 1
    • Pop the screen out from the front panel.
    • Be careful not to bend the front panel too much as it might break.
    Frag FixBot
  19. Insignia Flex 10.1 NS-P10A6100 Screen Replacement: Schritt 19, Bild 1 von 1
    • Lift the screen from the front panel to remove.
    Frag FixBot
Abschluss
The screen is now free from the device and can be replaced. To reassemble your device, follow these instructions in reverse order.
3 weitere Personen haben diese Anleitung absolviert.
Baylor, Team 5-8, Williams Fall 2016 Mitglied von Baylor, Team 5-8, Williams Fall 2016
BU-WILLIAMS-F16S5G8
3 Mitglieder
12 Anleitungen geschrieben
2 Kommentare zur Anleitung
Do you have a guide for replacing the lcd screen?
dcutler01 - Antwort Teilen
Whic screen models works wirt this tablet?
Gerardo Lerma - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 3,623
