Zum Hauptinhalt wechseln
Insignia Flex 10.1 NS-P10W8100 Battery Replacement
Was du brauchst
  1. Insignia Flex 10.1 NS-P10W8100 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Insignia Flex 10.1 NS-P10W8100 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
  2. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: Schritt 2, Bild 1 von 2 Insignia Flex 10.1 NS-P10W8100 Battery Replacement: Schritt 2, Bild 2 von 2
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to the edge closest to the screen.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: Schritt 3, Bild 1 von 1
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off, work your fingers around the corners and slowly pry the cover off using your fingers.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: Schritt 4, Bild 1 von 2 Insignia Flex 10.1 NS-P10W8100 Battery Replacement: Schritt 4, Bild 2 von 2
    • Unplug the power supply by disconnecting the red and blue wires found on the motherboard.
  5. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the black tape from the Zero Insertion Force (ZIF) ribbon connector.
  6. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: Schritt 6, Bild 1 von 2 Insignia Flex 10.1 NS-P10W8100 Battery Replacement: Schritt 6, Bild 2 von 2
    • Lift up on the black locking flap, being careful not to damage the surrounding hardware parts.
    • Remove the ZIF ribbon wire by pulling horizontally towards the battery.
  7. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: Schritt 7, Bild 1 von 1
    • Remove the black tape from the small ribbon wire connector.
    • Pull the ribbon connector out of the plug the same way that was mentioned in step 4.
  8. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: Schritt 8, Bild 1 von 1
    • Use the spudger to separate the battery from the base.
    • The battery can be difficult to remove as it is held in with double sided tape.
    • Be sure not to pry on the battery too hard because damage to the screen and/or the battery can occur.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare zur Anleitung
Very concise and helpful. Thank you
Frank Schaffer - Antwort Teilen
where can i buy the replacement battery?
José Porras - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 37
Insgesamt: 1,522
