Zum Hauptinhalt wechseln
Insignia Flex 10.1 NS-P10W8100 Speaker Replacement
Was du brauchst
  1. Insignia Flex 10.1 NS-P10W8100 Speaker Replacement, Speakers: Schritt 1, Bild 1 von 2 Insignia Flex 10.1 NS-P10W8100 Speaker Replacement, Speakers: Schritt 1, Bild 2 von 2
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
  2. Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to the edge closest to the screen.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off work your fingers around the corners and slowly pry the cover off.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 4, Bild 1 von 2 Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Using a fingernail, gently pull back on the yellow tape holding the speaker wire in place.
    • Looking on the right side of the device remove the second piece of tape the same way.
    • Try to place the the tape in a location with little dust for later when reinstalling the tape.
  5. Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 5, Bild 1 von 2 Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Remove the black tape covering the ribbon connector.
    • Then use a fingernail to lift up the black edge on top of the ribbon connector.
  6. Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 6, Bild 1 von 3 Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 6, Bild 2 von 3 Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 6, Bild 3 von 3
    • Gently pull on the speaker wire connector from the motherboard.
    • Then continue to slide the cable gently to clear it from other components.
    • The longer speaker wire has to be removed from under the smaller ribbon wire connected to the keyboard connector.
    • You may need to use the 0.8 tip tool to press down on the connector if it is not removing easily.
  7. Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 7, Bild 1 von 3 Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 7, Bild 2 von 3 Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 7, Bild 3 von 3
    • Using a Phillips #2 screwdriver, remove the two 4 mm screws holding the speakers in place.
  8. Insignia Flex 10.1 NS-P10W8100 Speaker Replacement: Schritt 8, Bild 1 von 1
    • Remove the speakers from the device.
    • Be sure to watch the speaker wires as they may snag on other items.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 303
