Zum Hauptinhalt wechseln
Insignia Flex 7 Battery Replacement
Was du brauchst
  1. Insignia Flex 7 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Insignia Flex 7 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Insignia Flex 7 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Insert the edge of the plastic opener into the grove between the screen and back cover around the perimeter of the device.
    • Then using a gentle prying motion, create a gap large enough to use your fingers to separate the two halves.
  2. Insignia Flex 7 Battery Replacement: Schritt 2, Bild 1 von 2 Insignia Flex 7 Battery Replacement: Schritt 2, Bild 2 von 2
    • Place the tip of the spudger on each side of the battery's electrical connector.
    • Then using a gentle match-striking motion, loosen both sides of the battery's electrical connector.
  3. Insignia Flex 7 Battery Replacement: Schritt 3, Bild 1 von 3 Insignia Flex 7 Battery Replacement: Schritt 3, Bild 2 von 3 Insignia Flex 7 Battery Replacement: Schritt 3, Bild 3 von 3
    • Insert the flat end of the spudger under one side of the battery.
    • Then using a gentle prying and sliding motion, separate the battery from the case. There are two lengthwise strips of glue holding it down.
    • Repeat the process for the other side of the battery.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Link for replacement battery?
Mike - Antwort
I'm also looking for a replacement battery and i've only found batteries with two cables instead of the 5 this one has
Jose Garza Lozano - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 942
