Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Ersatzteile
Keine Ersatzteile angegeben.
  1. Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet. You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Lift the back casing away from the rest of the device which should include the exposed circuit board and screen. Set the casing aside.
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Wedge a plastic opening tool in between the male, black module and female, white module  to disconnect the wires module from the circuit board. Wedge a plastic opening tool in between the male, black module and female, white module  to disconnect the wires module from the circuit board.
    • Wedge a plastic opening tool in between the male, black module and female, white module to disconnect the wires module from the circuit board.
  5. Use a plastic opening tool to pry the battery  from the circuit board by wedging it around the perimeter of the battery. Use a plastic opening tool to pry the battery  from the circuit board by wedging it around the perimeter of the battery. Use a plastic opening tool to pry the battery  from the circuit board by wedging it around the perimeter of the battery.
    • Use a plastic opening tool to pry the battery from the circuit board by wedging it around the perimeter of the battery.
  6. Remove the battery from the circuit board by lifting it with the spudger or finger.
    • Remove the battery from the circuit board by lifting it with the spudger or finger.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Jeremy Anaya
316 Reputation
2 Anleitungen geschrieben
Baylor, Team 6-7, Williams Fall 2015 Mitglied von Baylor, Team 6-7, Williams Fall 2015
BU-WILLIAMS-F15S6G7
3 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 5
Insgesamt: 1,764
