Was du brauchst
Begin by using the opening tool to pry open the back cover. Continue around the edge until the back cover pops off.
Use the opening tool to flip the LCD flex circuit plug upwards. The flex circuit should now be loose. Remove flex circuit by pulling outwards.
Pry the battery from the back of the LCD screen using the opening tool. Due to the strong adhesive between the battery and screen, this may take some time.
