Einleitung
If your battery is dying too quickly or it is faulty, this guide will help you. Use caution, a punctured battery could be extremely hazardous.
Was du brauchst
Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
Gently peel the tape that is covering the cable connections going to and from the battery and set tape aside.
Locate battery cable connection.
Pull gently on cable that connects the battery to the motherboard.
Slide the nylon spudger gently underneath the battery.
Using the nylon spudger, gently pry battery from adhesive on metal base.
Working around the battery, pry up all the sides to remove the battery from the metal base.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
We're do u get a new battery from ???
i know this is an old comment but the solution is the same, ebay the model number and you will find many parts for cheap! good luck!
mathew -
Pls help me to send me the phone number of the above mentioned Mattew or give him my phone number. I will discuss with him to replace my charger plug and possibly the battery. thanks.
