Zum Hauptinhalt wechseln
Insignia Flex 8 NS-P16AT08 Cameras Replacement
Was du brauchst
  1. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: Schritt 1, Bild 1 von 3 Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: Schritt 1, Bild 2 von 3 Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: Schritt 1, Bild 3 von 3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Cameras Replacement: Schritt 2, Bild 1 von 1
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Cameras: Schritt 3, Bild 1 von 1
    • Gently peel all of the tape that is covering the cable connections going to and from the cameras. Set the tape aside for later reassembly.
  4. Insignia Flex 8 NS-P16AT08 Cameras Replacement: Schritt 4, Bild 1 von 2 Insignia Flex 8 NS-P16AT08 Cameras Replacement: Schritt 4, Bild 2 von 2
    • Locate camera ribbon connector.
    • Using finger flip up black flap of camera ribbon connector.
  5. Insignia Flex 8 NS-P16AT08 Cameras Replacement: Schritt 5, Bild 1 von 1
    • Gently pull camera connector ribbon by hand until it separates from connector.
  6. Insignia Flex 8 NS-P16AT08 Cameras Replacement: Schritt 6, Bild 1 von 1
    • Using metal spudger tool, gently pry right speaker away from adhesive.
    • Always use a nylon spudger or plastic opening tool before a metal spudger. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • Move right speaker to left side of device so you can freely access the camera ribbon.
  7. Insignia Flex 8 NS-P16AT08 Cameras Replacement: Schritt 7, Bild 1 von 1
    • Using metal spudger tool, gently pry the rear-facing camera from the adhesive.
  8. Insignia Flex 8 NS-P16AT08 Cameras Replacement: Schritt 8, Bild 1 von 1
    • Lift up connector ribbon that is attached to the cameras.
    • Slide cameras and connector ribbon out from underneath the speaker cords and battery.
  9. Insignia Flex 8 NS-P16AT08 Cameras Replacement: Schritt 9, Bild 1 von 1
    • Remove connector ribbon and cameras from device casing.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 229
