Einleitung
If your tablet speakers are not working or you would like them to work better, follow this guide to replace them.
Was du brauchst
Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
There are two connections that attach the speakers to the motherboard.
Unplug the cables from the motherboard by gently pulling them away.
Gently pry both speakers away from adhesive with metal spudger tool.
The speakers can now be completely removed from the device.
