Zum Hauptinhalt wechseln
Insignia Flex 8 NS-P16AT08 Speakers Replacement
Was du brauchst
  1. Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: Schritt 1, Bild 1 von 3 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: Schritt 1, Bild 2 von 3 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: Schritt 1, Bild 3 von 3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Speakers Replacement: Schritt 2, Bild 1 von 1
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Speakers Replacement, Speakers: Schritt 3, Bild 1 von 2 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Speakers: Schritt 3, Bild 2 von 2
    • There are two connections that attach the speakers to the motherboard.
    • Unplug the cables from the motherboard by gently pulling them away.
    • Speaker cables will be free to be removed.
  4. Insignia Flex 8 NS-P16AT08 Speakers Replacement: Schritt 4, Bild 1 von 2 Insignia Flex 8 NS-P16AT08 Speakers Replacement: Schritt 4, Bild 2 von 2
    • Remove the tape that is holding the speaker cables down.
    • Remove the speaker cables from underneath the black connector ribbons.
    • The cables are hooked underneath black connector ribbons; carefully unhook them.
  5. Insignia Flex 8 NS-P16AT08 Speakers Replacement: Schritt 5, Bild 1 von 1
    • Gently pry both speakers away from adhesive with metal spudger tool.
    • Always use a nylon spudger or plastic opening tool before a metal spudger. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • The speakers can now be completely removed from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 208
