Zum Hauptinhalt wechseln
Insignia NS-B4111 Antenna Replacement
Was du brauchst
  1. Insignia NS-B4111 Antenna Replacement, Battery: Schritt 1, Bild 1 von 2 Insignia NS-B4111 Antenna Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unplug and remove the power cord. Turn the boombox upside down.
    • Grip the sides of the case and use your thumbs to pop open the battery cover.
  2. Insignia NS-B4111 Antenna Replacement: Schritt 2, Bild 1 von 2 Insignia NS-B4111 Antenna Replacement: Schritt 2, Bild 2 von 2
    • Pry out the batteries with your fingers.
  3. Insignia NS-B4111 Antenna Replacement, External Antenna: Schritt 3, Bild 1 von 1
    • Set the boombox upright. Remove the 4mm screw and the two 6mm washers with the Phillips PH1 screwdriver.
    • Remove the external antenna.
  4. Insignia NS-B4111 Antenna Replacement, Casing: Schritt 4, Bild 1 von 1
    • Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
    • Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
  5. Insignia NS-B4111 Antenna Replacement: Schritt 5, Bild 1 von 2 Insignia NS-B4111 Antenna Replacement: Schritt 5, Bild 2 von 2
    • Gently remove the bottom half of the casing from the top half of the casing.
    • The antenna base is connected to the motherboard by a red wire. This wire will prevent the two halves from separating completely.
  6. Insignia NS-B4111 Antenna Replacement, Antenna Base: Schritt 6, Bild 1 von 2 Insignia NS-B4111 Antenna Replacement, Antenna Base: Schritt 6, Bild 2 von 2
    • Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
    • This red wire will now be loose and you can move it out of the antenna base slot.
Abschluss
UC Davis, Team 1-5, Oliver Fall 2016 Mitglied von UC Davis, Team 1-5, Oliver Fall 2016
UCD-OLIVER-F16S1G5
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 794
