Einleitung
This product plays both CD's and Cassettes as well as AM/FM radio stations.
Before attempting this replacement, make sure to use a anti-static strap to prevent circuit damages to your device.
Was du brauchst
Turn the boombox around to see the back, and then flip it upside down.
Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
Peel off the two black square foams in front of the battery compartment to reveal a screw under each one.
Remove the two 8mm screws using a 2.5mm flathead driver.
The front grey panel will loosen up once the final screw is removed.
Turn the boombox on its back.
Release the front panel by pushing down on the latches holding the panels together.
There are four silver latches on the top side of the panel and one on the bottom.
Turn the boombox around to view the back and lift the handle up.
Using the same driver with 2.5mm flathead, remove the two 14mm screws under the handle.
Gently lift the black top but do not pull completely away.
Unplug the red and black wires from the large yellow motherboard by pulling upwards.
Unplug the thick, white and pink cord from underneath the black top by pulling downwards.
Using a Phillips #0, remove the two 11mm screws attached to the green legs underneath the top panel.
With a plastic opening tool, take off the red rings on the other two green legs.
Slide the silver bar out.
The square cube with the tiny lense is loosened. Slide it down to take out of the nook.
Detach the black tape so the cube is completely by itself. Replace the cube with a new one.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
