Zum Hauptinhalt wechseln
Insignia NS-CLIP02 Digital Display Replacement
Was du brauchst
  1. Insignia NS-CLIP02 Digital Display Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Digital Display Replacement: Schritt 2, Bild 1 von 2 Insignia NS-CLIP02 Digital Display Replacement: Schritt 2, Bild 2 von 2
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Digital Display Replacement: Schritt 3, Bild 1 von 2 Insignia NS-CLIP02 Digital Display Replacement: Schritt 3, Bild 2 von 2
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Digital Display Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Digital Display Replacement: Schritt 5, Bild 1 von 1
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Digital Display Replacement: Schritt 6, Bild 1 von 1
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Digital Display Replacement: Schritt 7, Bild 1 von 1
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Digital Display Replacement: Schritt 8, Bild 1 von 3 Insignia NS-CLIP02 Digital Display Replacement: Schritt 8, Bild 2 von 3 Insignia NS-CLIP02 Digital Display Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the four cables connecting the motherboard to the device.
  9. Insignia NS-CLIP02 Digital Display Replacement, Digital Display: Schritt 9, Bild 1 von 1
    • Using the Phillips screwdriver, remove the three screws that run along the center of the base.
  10. Insignia NS-CLIP02 Digital Display Replacement: Schritt 10, Bild 1 von 2 Insignia NS-CLIP02 Digital Display Replacement: Schritt 10, Bild 2 von 2
    • Carefully remove the base.
  11. Insignia NS-CLIP02 Digital Display Replacement: Schritt 11, Bild 1 von 2 Insignia NS-CLIP02 Digital Display Replacement: Schritt 11, Bild 2 von 2
    • Using the metal spudger, gently lift the face plate away from the display.
  12. Insignia NS-CLIP02 Digital Display Replacement: Schritt 12, Bild 1 von 1
    • Once the face plate is removed, use the Phillips screwdriver to remove the six screws shown here.
  13. Insignia NS-CLIP02 Digital Display Replacement: Schritt 13, Bild 1 von 2 Insignia NS-CLIP02 Digital Display Replacement: Schritt 13, Bild 2 von 2
    • Using the metal spudger, lift the speaker grilles from the display.
    • The speaker grilles will hinge on the side closest to the display.
  14. Insignia NS-CLIP02 Digital Display Replacement: Schritt 14, Bild 1 von 1
    • Using the Phillips screwdriver, remove the four screws shown here.
  15. Insignia NS-CLIP02 Digital Display Replacement: Schritt 15, Bild 1 von 2 Insignia NS-CLIP02 Digital Display Replacement: Schritt 15, Bild 2 von 2
    • The two pieces of the display should easily separate.
  16. Insignia NS-CLIP02 Digital Display Replacement: Schritt 16, Bild 1 von 1
    • Using the Phillips screwdriver, remove the three screws shown here.
  17. Insignia NS-CLIP02 Digital Display Replacement: Schritt 17, Bild 1 von 3 Insignia NS-CLIP02 Digital Display Replacement: Schritt 17, Bild 2 von 3 Insignia NS-CLIP02 Digital Display Replacement: Schritt 17, Bild 3 von 3
    • The digital display should now be easy to remove.
    • Replace with new part.
Abschluss
Aubrey
214 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 9-3, Leahy Winter 2015 Mitglied von USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 473
