Zum Hauptinhalt wechseln
Insignia NS-CLIP02 Keypad Replacement
Was du brauchst
  1. Insignia NS-CLIP02 Keypad Replacement, Keypad: Schritt 1, Bild 1 von 1
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 Keypad Replacement: Schritt 2, Bild 1 von 1
    • Begin by using a metal spudger to peel back the adhesive sticker and locate the 11mm screw beneath the sticker.
  3. Insignia NS-CLIP02 Keypad Replacement: Schritt 3, Bild 1 von 1
    • Locate the 11mm screw beneath the sticker.
  4. Insignia NS-CLIP02 Keypad Replacement: Schritt 4, Bild 1 von 1
    • Using a plastic spudger, peel off the adhesive gel stoppers.
  5. Insignia NS-CLIP02 Keypad Replacement: Schritt 5, Bild 1 von 1
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Insignia NS-CLIP02 Keypad Replacement: Schritt 6, Bild 1 von 1
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Insignia NS-CLIP02 Keypad Replacement: Schritt 7, Bild 1 von 1
    • Once you peel off the bottom from the device, you will see the motherboard.
  8. Insignia NS-CLIP02 Keypad Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Insignia NS-CLIP02 Keypad Replacement: Schritt 9, Bild 1 von 1
    • Lift the motherboard from the device.
  10. Insignia NS-CLIP02 Keypad Replacement: Schritt 10, Bild 1 von 1
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Insignia NS-CLIP02 Keypad Replacement: Schritt 11, Bild 1 von 1
    • Begin with removing the plug to your left.
  12. Insignia NS-CLIP02 Keypad Replacement: Schritt 12, Bild 1 von 1
    • Remove the plug to your right from the motherboard.
  13. Insignia NS-CLIP02 Keypad Replacement: Schritt 13, Bild 1 von 1
    • Remove the plug in the front of the lcd screen plug.
  14. Insignia NS-CLIP02 Keypad Replacement: Schritt 14, Bild 1 von 1
    • Remove the LCD screen plug last. Then, follow the following instructions in reverse, replacing the old motherboard with the new one to fix the keypad.
Abschluss
Erik
405 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 9-3, Leahy Winter 2015 Mitglied von USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 147
