Zum Hauptinhalt wechseln
Insignia NS-CLIP02 Speaker replacement and troubleshooting
Was du brauchst
  1. Insignia NS-CLIP02 Speaker replacement and troubleshooting, Motherboard: Schritt 1, Bild 1 von 1
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 2, Bild 1 von 2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 2, Bild 2 von 2
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 3, Bild 1 von 2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 3, Bild 2 von 2
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 4, Bild 1 von 1
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 5, Bild 1 von 1
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 6, Bild 1 von 1
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 7, Bild 1 von 1
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 8, Bild 1 von 3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 8, Bild 2 von 3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 8, Bild 3 von 3
    • Disconnect the four cables connecting the motherboard to the device.
  9. Insignia NS-CLIP02 Speaker replacement and troubleshooting, Speaker: Schritt 9, Bild 1 von 1
    • Remove the three screws located along the center of the base.
  10. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 10, Bild 1 von 2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 10, Bild 2 von 2
    • Remove the base from the display.
  11. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 11, Bild 1 von 3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 11, Bild 2 von 3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 11, Bild 3 von 3
    • Using a metal spudger, remove the plastic face plate from the display.
  12. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 12, Bild 1 von 1
    • With a phillips screwdriver, remove the six screws shown pictured to the left.
  13. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 13, Bild 1 von 2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 13, Bild 2 von 2
    • Using the metal spudger, pry the speaker grilles from the display.
  14. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 14, Bild 1 von 1
    • Using the phillips screwdriver, remove the four screws pictured to the left.
  15. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 15, Bild 1 von 1
    • Separate the two pieces of the display as shown.
  16. Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 16, Bild 1 von 3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 16, Bild 2 von 3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: Schritt 16, Bild 3 von 3
    • You can see that there are several points where connections to the speaker are soldered.
    • If all connections are soldered then replacement may be necessary.
Abschluss
Aubrey
214 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 9-3, Leahy Winter 2015 Mitglied von USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 9
Insgesamt: 173
