Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will show users how to open the casing of the Insignia NS-CLLT01 in order to make necessary repairs.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail. Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
    • Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
  2. On the bottom of the clock, use your fingernail to push the battery cover to the right. Lift the battery cover up and to the right to reveal the batteries. Lift the battery cover up and to the right to reveal the batteries.
    • On the bottom of the clock, use your fingernail to push the battery cover to the right.
    • Lift the battery cover up and to the right to reveal the batteries.
  3. Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
    • Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
    • Once the batteries are removed, close the cover.
  4. Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
    • Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
    • Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
    • The screws may not come out of the bottom of the clock. As long as you have unscrewed them, the clock can still be opened.
  5. Turn the clock back over. Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up. Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
    • Turn the clock back over.
    • Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
Ziellinie
Morgan Mattingly
301 Reputation
3 Anleitungen geschrieben
Baylor, Team 6-9, Williams Fall 2015 Mitglied von Baylor, Team 6-9, Williams Fall 2015
BU-WILLIAMS-F15S6G9
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 43
