Einleitung
This guide will show users how to open the casing of the Insignia NS-CLLT01 in order to make necessary repairs.
Was du brauchst
Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
On the bottom of the clock, use your fingernail to push the battery cover to the right.
Lift the battery cover up and to the right to reveal the batteries.
Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
Once the batteries are removed, close the cover.
Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
Turn the clock back over.
Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
