Was du brauchst
First, remove the front screen. (See prerequisite screen removal guide.)
Use the plastic opening tool to gently pry the motherboard forward and away from the rest of the device.
Gently lift the motherboard up and out, making sure that you don't disassemble any of the wires in place by pulling too hard.
To fully remove the motherboard from the clock, use wire cutters to carefully sever the connections between the motherboard and the wires attached.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
