Einleitung
Is the power button no longer powering on your device? This guide will help replace the power button so you can turn your speaker on and off.
Was du brauchst
Push the Spudger into the crevice between the grated panel of the speaker and the base of the speaker.
Angle the spudger to create a separation between the grate and the base.
Slide the spudger along the separation between the grate and the base of the speaker to loosen the grate. Do this to the entire perimeter of the speaker.
Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
Push the spudger into the crevice between the base and the face of the speaker and create a separation.
Slide the spudger along the entire perimeter and gently pull off the face of the speaker.
Use the spudger to release the battery by sliding it underneath the battery to create a separation.
Remove the battery.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
