Einleitung
If your speakers no longer sound strong/clear or they stopped producing sound, you may need to replace them. Use this guide to help you replace he speakers.
Was du brauchst
Insert the Spudger between the grated panel and the base of the speaker.
Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
Insert the Spudger between the corners of base and the face of the speaker to open the device.
The screw on the upper right corner may be difficult to take out. If you cannot take it out with a screwdriver, using force to pull the face of the speaker apart may break the plastic that surrounds the screw.
Ein Kommentar
This is a good app really could help some people like myself. Thank you
