Einleitung
If there are major problems with your Insignia NS-D160A14's functionality, it could be due to a faulty motherboard. This short guide will teach you how to remove the motherboard so it can be replaced. The process is very easy, so let's get started!
Was du brauchst
Remove the two 7mm Phillips #2 screws from the back of the DVD player.
Unhook the 4 hooks on the main casing.
There is one hook on the top of the casing, one on the bottom, and one on each side.
Keeping the 8-pin connector as straight as possible, lift the motherboard out of case.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
