Zum Hauptinhalt wechseln
Insignia NS-D160A14 Optical Drive Replacement
Was du brauchst
  1. Insignia NS-D160A14 Optical Drive Replacement, Outer Case: Schritt 1, Bild 1 von 1
    • Unplug the power cord before proceeding to open the DVD player's enclosure.
    • Remove the two 7mm Phillips #2 screws from the back of the DVD player.
  2. Insignia NS-D160A14 Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Carefully lift the outer case up, starting from the back.
    • Removing the outer case may require some force, and you will need to get the case into an angled position compared to the rest of the DVD player before it can be completely separated.
  3. Insignia NS-D160A14 Optical Drive Replacement, Front Panel: Schritt 3, Bild 1 von 3 Insignia NS-D160A14 Optical Drive Replacement, Front Panel: Schritt 3, Bild 2 von 3 Insignia NS-D160A14 Optical Drive Replacement, Front Panel: Schritt 3, Bild 3 von 3
    • Unhook the 4 hooks on the main casing.
    • There is one hook on the top of the casing, one on the bottom, and one on each side.
    • These hooks are brittle and can easily break.
  4. Insignia NS-D160A14 Optical Drive Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Remove the central 7 mm screw holding the motherboard in place.
    • Be sure to ground yourself before manipulating the motherboard. A static shock could render one or more components on the motherboard useless.
  5. Insignia NS-D160A14 Optical Drive Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the white power cord connector from the motherboard.
  6. Insignia NS-D160A14 Optical Drive Replacement: Schritt 6, Bild 1 von 2 Insignia NS-D160A14 Optical Drive Replacement: Schritt 6, Bild 2 von 2
    • Keeping the 8-pin connector as straight as possible, lift the motherboard out of case.
    • You may need to bend the side of the case slightly to give the motherboard room to be lifted out.
  7. Insignia NS-D160A14 Optical Drive Replacement, Optical Drive: Schritt 7, Bild 1 von 2 Insignia NS-D160A14 Optical Drive Replacement, Optical Drive: Schritt 7, Bild 2 von 2
    • Disconnect the white cables connected to the optical drive from the A/V board using your fingers.
    • Be careful when removing the cables on the A/V board. Don't put too much pressure on the wires or the wires could be damaged.
  8. Insignia NS-D160A14 Optical Drive Replacement: Schritt 8, Bild 1 von 1
    • After removing the white wires connected to the A/V board, the optical drive should slide out of the slot.
Abschluss
Ian Hanken
516 Reputation
5 Anleitungen geschrieben
University of Memphis, Team 1-5, Kim SU 2016 Mitglied von University of Memphis, Team 1-5, Kim SU 2016
UM-KIM-SU16S1G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 370
