Zum Hauptinhalt wechseln
Insignia NS-D160A14 Power Cord Replacement Guide
Was du brauchst
  1. Insignia NS-D160A14 Power Cord Replacement Guide, Outer Case: Schritt 1, Bild 1 von 1
    • Unplug the power cord before proceeding to open the DVD player's enclosure.
    • Remove the two 7mm Phillips #2 screws from the back of the DVD player.
  2. Insignia NS-D160A14 Power Cord Replacement Guide: Schritt 2, Bild 1 von 1
    • Carefully lift the outer case up, starting from the back.
    • Removing the outer case may require some force, and you will need to get the case into an angled position compared to the rest of the DVD player before it can be completely separated.
  3. Insignia NS-D160A14 Power Cord Replacement Guide, Power Cord: Schritt 3, Bild 1 von 1
    • The power cord has a molded connector that fits in a slot punched out of the back left corner of the DVD player near the A/V jacks.
    • There are no screws that fasten the power cord connector to the DVD player's enclosure.
    • Be careful not to cut yourself on the potential sharp edges of the DVD player's contoured enclosure.
  4. Insignia NS-D160A14 Power Cord Replacement Guide: Schritt 4, Bild 1 von 2 Insignia NS-D160A14 Power Cord Replacement Guide: Schritt 4, Bild 2 von 2
    • The power cord's white plastic plug is located on the DVD player's mother board.
    • Unsnap the power cord's white plastic plug from the mother board, and gently slide the male and female white plastic plug connections apart.
    • Be careful not to be too rough when disconnecting the white plastic plug from the motherboard; the motherboard could be easily damaged.
  5. Insignia NS-D160A14 Power Cord Replacement Guide: Schritt 5, Bild 1 von 1
    • Firmly grasp the power cord's molded connector with two fingers and slide up.
    • Finally, remove the power cord from the DVD player's assembly.
    • As you slide the power cord's molded connector, you may need to gently wiggle it about to help facilitate its removal.
Abschluss
Ian Hanken
516 Reputation
5 Anleitungen geschrieben
University of Memphis, Team 1-5, Kim SU 2016 Mitglied von University of Memphis, Team 1-5, Kim SU 2016
UM-KIM-SU16S1G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 31
Insgesamt: 1,361
