Einleitung
The power cord is a 110 Volt small appliance pigtail that is factory assembled to the DVD player.
If the power cord needs to be replaced, this technical guide will show the steps needed to properly get it done. The process is fairly straight forward and not difficult.
Note: Unplug the power cord before proceeding to remove it from the DVD player.
Was du brauchst
Remove the two 7mm Phillips #2 screws from the back of the DVD player.
The power cord has a molded connector that fits in a slot punched out of the back left corner of the DVD player near the A/V jacks.
There are no screws that fasten the power cord connector to the DVD player's enclosure.
The power cord's white plastic plug is located on the DVD player's mother board.
Unsnap the power cord's white plastic plug from the mother board, and gently slide the male and female white plastic plug connections apart.
Firmly grasp the power cord's molded connector with two fingers and slide up.
Finally, remove the power cord from the DVD player's assembly.
